Equipotential bonding of the perimeter surfaces is not required if the installation meets the following conditions in 680.42(B) 1-4:
- The spa or hot tub shall be listed as a self-contained spa for aboveground use.
- The spa or hot tub shall not be identified as suitable only for indoor use.
- The installation shall be in accordance with the manufacturer’s instructions and shall be located on or above grade.
- The top rim of the spa or hot tub shall be at least 28 in. above all surfaces around the hot tub that are within 30 in., measured horizontally from the spa or hot tub. The height of nonconductive external steps for entry to or exit from the self-contained spa shall not be used to reduce or increase this rim height measurement
A spa or hot tub must be listed by one of the third party testing agencies like UL, Met Labs, or ETL and meet all of the conditions in 680.42(B) if an equipotential bonding grid is not installed.
Here is a list of the most common electrical mistakes made when installing a hot tub outdoors
www.jadelearning.com
