I have my pool nearly ready to open. 15,000 vinyl above ground. It has fc at 0 (for the last day) due to an citric acid treatment. Polyquat 60 has been used. PH is at 7.0 due to the addition of citric acid yesterday (I will use AA in the future as I now understand the better binding properties of AA and less downsides such as chloroform formation with CA). TA is at 120 and CYA at 0 but getting some in Tuesday to bring up to standard levels. Before I start raising my FC over the next week to see once it holds, I need to dose the sequestrant. The further reading on the ascorbic acid treatment mentions to keep ph at 7.2 during the addition of the sequestrant. However, on the bottle of metal magic it says to take up to 7.5 or higher. Do I adjust the PH to 7.2 as in the guide or follow the bottle and raise it to 7.5? Also, since my TA is at the upper limit, I know I should aerate to raise it but if I used borax instead, would that significantly add to the TA? I just don't have an effective aeration setup and I will have to wait God knows how long for my return pump to do all the aeration. Thank you for your help!
