Emergency shut-off switch required or is it optional?
jmk396
45
PA
Is it required to have an emergency shut-off switch for an above-ground pool?
I'm planning to have two electrical circuits:
1) Pump -> Timer
2) Pool Heater (110v, natural gas)
If I need a shut-off switch, does it need to turn off the heater too? Do I need something like a DPDT (double-pull, double-throw) switch to shut off BOTH circuits at the same time?
PoolGate
6,437
Damascus, MD
Jandy Aquapure 1400
I have never heard of this anywhere.
jmk396
45
PA
Thanks ... I'm really not sure because I've read different things about a shut-off switch.
I've also been told that if the pump has a standard electrical plug that you can unplug it from the outlet and that qualifies for the disconnection rule.
Jimrahbe
22,816
Bedford, TX
396,
Let's wait for JohnT, but I believe that any sub panel near the pool counts as the emergency shut off..
jmk396
45
PA
I don't have a sub-panel near the pool... (I do have a sub-panel, but it's in the basement next to the main panel for extra circuits because my main panel is full)
I'll wait for @JohnT since it sounds like he's the expert :)
EDIT: I want to place the electrical outlets on the house because the pool will be close to it. I also had a gas line installed on the house for the pool heater:
Thanks!
Jimrahbe
22,816
Bedford, TX
396,
You might also check on what code says about putting a heater below a window... :confused:
If this were my setup, I'd want two circuit breakers inside the "timer" box... One for the pump and one for the heater.
ajw22
28,518
Northern NJ
Pentair Intellichlor IC-60
Pump timer has a manual switch that qualifies as a manual shutoff by the equipment pad.
ajw22
28,518
Northern NJ
roomruler
19
Winnipeg
Allen’s got it covered (y)
Hi John,
I just have a new pump timer installed. At first I thought the manual override switch inside the timer was like a main breaker (if you manually set it off, timer could not turn it back on unless you manually do so). Then I realized the switch actually is mechanically controlled by the timer. That means, when I clean the pump, the timer actually is able to turn the pump back on.
So I don’t get why it’s still qualified as a shut off?
Thanks
JohnT
Admin
10,041
SW Indiana
Hi John,
Thanks
The purpose of the shut off is for an emergency such as a person being entrapped by suction.
We’ve had plenty of users post mishaps where the used the timer shut off while working on the plumbing, only to have the timer turn the pump on the next morning and drain the pool or run the pump drive and damage it.
roomruler
19
Winnipeg
Thanks for the clarification.
So you mean in fact it’s not violating any code not having another separated switch next to the timer? I should be fine to use timer switch to shut down the pump for a while for basic maintenance like cleaning pump strainer?
ajw22
28,518
Northern NJ
If you want to stop an Intermatic timer from turning on remove the ON trippers.
JohnT
Admin
10,041
SW Indiana
IIRC, it has to be visible to meet code.
roomruler
19
Winnipeg
Thanks Allen. But I guess most people will not bother doing so when just to clean the pump strainer.
It seems to be a common practice to use timer switch to shut down the pump for a while. I’ll keep in mind, when further service is needed for the pump, cutdown the power from panel.
Randrx2
374
Orlando, FL
Allen,
680.41 would not apply, correct? This does not apply to one-family dwellings. Is this the 2020 NEC? The 2017 NEC still only has this spas and hot tubs.
JMK396,
Basically, as Allen showed, 680.13 discusses the maintenance disconnecting means. You need a maintenance disconnect for each piece of equipment. If it plugs in, and you can remove the plug, that qualifies. Your cord should be a twist lock plug. If not, the breaker can serve as the disconnect, as long as it is within site of the equipment. If you install a switch, make sure it is rated for the amperage of the equipment. If it is 240V, then use a double pole switch.
ajw22
28,518
Northern NJ
Allen,
Yes, that is the new 680.41 from the 2020 NEC.
I have seen the type of electrical disconnect box used alongside AC compressors used to satisfy the disconnect requirement for a 240V pump where the breaker was not within sight of the pump.
ajw22
28,518
Northern NJ
Thanks! No where around here is using 2020. We are lucky to find a jurisdiction using 2017. I’m actually on a current project where the plans called for 2008 NEC code to be used!
I just quote the current code. I don't know what is in force in a given location.
