My cya was 70. I slammed the pool due to algae outbreak. It passed and FC is now down to 18. CYA is now saying 40?
any idea what’s going on?
No.i was wondering if FC binds with the CyA and stops it precipitating, or something like that...
Tom, you have asked the same question three times and each time you have been told NO. I have no idea what you want to hear but the CYA doesn't degrade from the presence of high FCMaybe the very high Fc during the slam degraded the CYA?
Truth............
Your high levels of FC very likely did not break down the CYA. This has somewhat been discussed in this thread some time ago. I'd love to share a quick quote that simplifies the thread but truth be told, I'm also fighting the kids to go to school.
The primary step is the cleavage of the triazine ring and it is proposed by Wojtowicz that this primarily involves a fully chlorinated isocyanurate species Cl2CY-. The decomposition was first order with respect to average chlorine and increased with pH. The decomposition rate was a decrease in Free Chlorine at a rate of 0.0147 per hour or 1-EXP(-0.0147*24) = 30% per day while the calculated rate of loss of CYA at 4 ppm FC was 0.87 ppm per day [EDIT] (I get 4*0.30/2.47 = 0.49 ppm CYA per day) [END-EDIT], but that was at FC/CYA ratios (in ppm units) of 0.34 (close to shock levels) whereas the more typical ratio in our pools is around 0.1. His experiments at lower FC/CYA ratios of 0.029 with 4 ppm FC and 138 ppm CYA showed a lower CYA decomposition rate of 0.24 ppm/day which is a factor of 3.6 lower. At 4 ppm FC and 11.76 ppm CYA (a ppm ratio of 0.34), the concentration of Cl2CY- (at temp 85F) is a factor of 9.9 higher while HClCY- is a factor of 6.9 higher than the concentrations at 4 ppm FC and 138 ppm CYA which might mean that HClCY- is the rate-critical species that degrades (this is speculation on my part). In another paper "Effect of Cyanuric Acid on Swimming Pool Maintenance" (in the same JSPSI collection), Wojtowicz describes a chlorine loss rate due to oxidation of CYA at 12.5% per day at 85F which is roughly consistent with a 30%/3.6 = 8.3% rate especially since his 12.5% number came from FC levels starting higher (5.4 ppm for indoor pools, 7.6 to 9.2 ppm for outdoor pools). So, assuming a CYA loss rate of around 0.4 ppm/day in our pools this comes to 12 ppm per month which is clearly enough to be noticeable as the months pass during a swim season. If one shocks the pool, then the rate of loss could be about 2-3 times faster.
Wojtowicz also shows a strong temperature dependence on the chlorine oxidation of cynauric acid where every 10F increase in temperature results in roughly doubling the rate of degradation. So his data was with pools at 85F so pools at 90F could have degradation rates about 1.4 times higher.
The thing is that some of what Wojtowicz has seen does not seem to be consistent with some of what we have seen in our own pools, especially with regard to chlorine loss rates. Wojtowicz implies that there is little breakdown from sunlight of the chlorinated isocyanrates -- that only hypochlorous acid and especially hypochlorite ion are affected. Yet the experiments mas985 (Mark) made showed that higher levels of CYA did protect chlorine better in a non-linear way in sunlight and he did not see losses overnight (that is, without sunlight) which Wojtowicz saw in indoor pools. My own pool is at 86-90F and is exposed to sunlight 1-2 hours most days (it has an opaque electric safety cover on most of the time) and about a 1 ppm FC per day loss which includes use of the pool (1 person bather load most days). The rate of chlorine loss from oxidation of CYA is, in ppm units, about 2.5 times higher so even if I assume 1 ppm FC loss per day all oxidizing CYA, that would be 0.4 ppm CYA loss per day or 12 ppm per month. I should be able to measure that as I started with 30 ppm CYA when I opened and added more CYA around April/May. [EDIT] I just measured my pool's CYA level and it's a little above 25 ppm so even attributing a 5 ppm CYA drop over 3 months, that's pretty low and could be explained by the error tolerance of the test or some by splash-out (I have an oversized cartridge filter that is only cleaned once a year so the only dilution is from splash-out). It's certainly not near 12 ppm per month of loss. [END-EDIT]
So I can see that it is possible for CYA to degrade slowly over time in pools that are at higher temperature or at higher FC/CYA ratios such as extensive periods of shocking....
Leebo,
ok, unlikely the CYA has been degraded by that much in such a short time.
CCL did have issues with the 50ppm standard solution. I encountered this myself. Is that what you meant or did they have reagent issues too?
in any case I’ve been using the same CCL reagents both before and after my fall in CYA numbers.
