Edge-25 with 2 speed pump question
douglasj76
52
Westlake, Ohio
So I installed a circupool Edge-25 and so far working good. I have a 2 speed pump that I run on low 24hrs a day. Reason I do that is I have a heater and like to keep the pool at a steady temp. Is it OK to run the SWG 24 hrs a day? Obviously keeping the SWG on a low setting as to not over chlorinate the pool. I think the lowest setting is 12% on a roughly 12k gallon pool. Or do I need get a timer to run the SWG for part of the day?
markayash
2,521
Atlanta Ga
I have the Edge 40 and run on low for 24 hours a day. If you find your free CL is too high you can add a timer.
I installed a 120V plug and just use a smart plug but haven’t had to cut mine back.
Reactions: douglasj76
markayash
2,521
Atlanta Ga
I was out of town on vacation for 10 days and my son said they had a few bad storms here. Even hailed one day so was expecting a semi green pool like in the past
I Am happy to say FC is still at 7 and the water is crystal blue. Dolphin got most of the junk off the bottom but the basket was 75% full and a few are bigger tree pieces
douglasj76
52
Westlake, Ohio
Been running my edge 25 for a few days now. 24/7 on the lowest setting. Chlorine seems to be stable and not getting too high(test every morning). Also, so far so good on my pumps low speed and not triggering the units low flow sensor. I installed a outdoor timer just in case I need to run the SWG part time, and have it wired ready to go. So happy we converted to salt. Water feels great, and not having to use tablets / dump liquid chlorine is so nice.
Reactions: mknauss
markayash
2,521
Atlanta Ga
What are you running your FC at? Just don't make my mistake and get it too low :) I tried 3 and regretted it after a hard rain ;(
I am running mine at 2/8 now and it seems to be staying around 6
