eBay 50lb bucket worth it?
primuspaul
91
NYC area
jblizzle
43,238
Math looks reasonable.
You will need to monitor your rising Calcium levels to avoid scaling.
Granted in your location you likely get a fair amount of rain in the short season and drain off a good bit of the pool for the winter, so the CH rise may not be a problem.
Are you setting and monitoring your CYA level and then maintaining the proper FC level for it? FC/CYA Chart
primuspaul
91
NYC area
I'm SLAMing right now. Total CYA added was 40, but level was only 25 shortly after addition. I think it takes a bit to dissolve. Trying to keep FC at 12. Will test CYA tomorrow.
