- Jul 31, 2022
- 9
- Plaster
- Pentair Intellichlor IC-40
<Posted elsewhere but got the message that the thread was inactive, so summarizing here>
I had the 12A breaker pop on my EasyTouch that uses an IC40. The pool maintenance guys said it was a bad breaker, so I dutifully replaced it only to have the same problem. I tracked down the problem to the Surge board (521593). It turns out that there are two functions for this board:
1. Protect the communication lines between the controller and chlorinator from electrical surges. This is done using clamping diodes and is normally non-destructive, but sometimes the diodes are overloaded and fail. (Some pictures in this forum of this kind of failure).
2. Rectify the 24VAC from the transformer through a full-wave bridge rectifier to get ~32VDC for the IC40.
In my case the rectifier has failed with a direct short from one AC leg to the Positive voltage terminal. I only hope the IC 40 was not damaged.
I don't know if the unit is still under warranty, but if not I'll replace the component on the board with a heavier duty bridge (25A instead of 12.5A). The component cost is literally $4.00. An entirely new board is $250. I'm an electrical engineer and have dealt with similar systems before. The most common issue is failure due to exceeding current specs, and the component is chosen for lowest cost.
So, just wondering if anyone else has tried this? I'll let everyone know how it goes, but I have to say that it seems that for this failure the fix can be a lot cheaper than what I've been reading about.
