Hi Folks,
My pool technician recently installed a new Easy Touch 8 system. I have two pumps: pump #1 pool/spa and pump #2 bubbler/laminar.
The valve for pump #2 is the issue. Proper valve operation should be to default to the bubbler. However, when pump #1 turns on it also activates the bubbler/laminar valve to laminar position. When pump #1 turns off, the bubbler/laminar valve activates to move the valve to bubbler position.
When I select the bubbler on the Easy Touch remote, the valve remains open in laminar position and won't move to open for the bubbler.
I can manually operate the bubbler in service mode, so I presume there is some kind of a configuration issue.
I'm confused by the menu options and fearful I might screw up the other configurations that the technician input.
When launching the Menu> F. Circuits (Feature Circuits), I see that Feature 1 is [ON] and Feature 2 - 8 is [OFF] but don't have a clue what that means or how (or if) it relates to the valves.
Has anybody seen this kind of trouble before?
Thanks in advance for your help.
Dan
Dan
