Dual main drains, dual side wall drains, one skimmer and one three-way diversion valve to control them all; what is the goal of this setup?
WWaynesWhirled
4
Phoenix
My pool was put in a year before I bought the house 15 years ago, and I have been pretty trouble free for the most part, but I never understood the suction setup on the pool. It has:
1. Dual main drain, over 3ft distance between (almost impossible to see in pic)
2. Dual side wall drain, over 3ft distance between (yes, I need a new cover!)
3. One skimmer. (see pic for all of the above)
4. One three-way valve to adjust suction between all these (see other pic).
Obviously the valve is trading off the suction on these three (I need to do a quick test to see which is which, since it was written in marker years ago and has long faded, though I know to the left is "skimmer"), but I am not familiar enough to know why you would put the diverter in any given position. Is this a common setup, and can anyone explain why I might be moving the suction between these three? Any thoughts appreciated.
Thanks!
mknauss
34,572
Laughlin, NV
Welcome to the forum!
The drains on the floor and the wall are tied together in pairs. The floor ones together and the wall ones together. They must do that to meet the Virginia Graeme Baker Act requirements for anti-entrapment.
Do you have any kind of water feature? Typically wall suction ports are for a water feature.
I suggest you read ABC's of Pool Water Chemistry.
Jimrahbe
20,188
Bedford, TX
Wayne,
The most logic thought would be the valve you show selects between the main drain and the skimmer.. The wall ports should go to a separate waterfall or water feature pump..
Show us a pic of the entire equipment pad.
WWaynesWhirled
4
Phoenix
Thanks for the info! It turns out that I DO have a water feature that is a whole extra pump next to the pool pump that pumps water up to a trough on top of the wall around the pool, like a little river. I wonder how changing the diverter would affect all these?
WWaynesWhirled
4
Phoenix
Wayne,
Here is the whole pad; pool pump, water feature pump (you were right about that), and two diverters.
Jimrahbe
20,188
Bedford, TX
Wayne,
The valve, in front of the pump with the filter, should select between skimmer and main drain.
The other pump just sucks water from the wall ports and I "assume" the valve on the left of your equipment pad, is on the pumps return side, and sends to water to two difference water features or ??? Your guess is as good a mine,, Shut off one pipe at a time, and see what happens.
WWaynesWhirled
4
Phoenix
Wayne,
Jim,
That makes sense. I'll check them one at a time and see what's up.
Thanks!
Wayne
Reactions: Jimrahbe
