Drain Water to Winterize
Dave224
4
Fargo, ND
Move from HERE
I also need to drain down my first year pool for winterizing. The guy closing it wants me to drain it down not just below the skimmers but also below the returns. And I want to do that to lower the CYA for next year. The problem is the overnight temps. F will be in the low 20’s and I want to keep the water circulating through the equipment until everything is blown out. My question is will the main drain alone supply enough water to do this? One of 3 supply pipes. I can turn down the speed of the pump. Seems like this should work. Any other way better?
ajw22
22,000
Northern NJ
Pentair Intellichlor IC-60
You only know if you try your pump drawing from the main drain only. You may need to adjust the speed of the pump so it is not trying to pull more water then the main drain can supply.
For one day temps falling into the 20's is not likely to be a problem anyway. Read...
anthonypool89
591
Berks County, PA
Why? From rain, etc. the water level wil likely come up above the returns anyway. Assuming you're plugging the lines either way, I'd rather be sure that they are effectively plugged by knowing that no air bubbles are coming through once the plugs are in. At any rate, that's a heck of a lot of water to pump out.
