Drain hardware for solar panels
azali
21
Got a new roof and getting ready to install the solar panels. I hear I need to drain them in the winter but I don't know what product I need to install into the PVC pipe.
Also, does anyone know anything about a new ordinance in San Ramon, CA that requires panels be connected to aluminum runners?
AND, my new roof is white composite shingles. Is it okay to lay the panels on top?
Any other help you can give me about the installation. The plumbing already goes up to the roof so I only need roof advice.
Thanks!
jblizzle
43,260
To drain them, I just added a PVC Tee with a 3/4" reducer that I screwed a brass spigot into at the lowest point of my panels. I open it in winter so all the water is drained.
Not sure what you mean by the aluminum runners. The panels do expand and contract as they heat and cool, so that could rub on your shingles. Perhaps that is what the runners are for?
azali
21
Thanks, another question. my PVC from the pump to the roof is 1 1/2". The panels are 2".
Should I reduce to 2's to 1 1/2 or use a coupler that is 1 1/2" then up to a 2"?
jblizzle
43,260
There is only one adapter between the two. You will need the reducer and a 2" coupler.
Recommended you use 2" as much as you can.
