Drain and Refill Question
lauren_balty
4
San Antonio, TX
Hello,
New to all of this. Bought a house with a pool and learning how to get the chemicals balanced. We discovered CYA is high and finally drained about 90% of the pool and currently filling it back up (as I type!). The recommended test kit was ordered and may take a week to arrive. My biggest question is what should I do until then? I have a basic water testing kit and can bring a sample to Leslie's to check the CYA. Also, we have a feeder with the 3" chorine tabs in it. I now know those contain CYA, but the pool builder says it should always be in use (pool is pretty new and still under warranty...and also states that a reputable pool company must test water each month), but I hear that those tests can be way off and unnecessary products will be pushed. Oh, and the previous owner's have the pump running during the day, but since chlorine should be added in the evening, wouldn't it make more since to run the pump throughout the night? I will post chemical levels as soon as the pool is completely filled, but any advice in the meantime is welcome!
Thank you!!
JJ_Tex
719
Prosper, TX (DFW)
I assume you are on city water, and not a well?
If so, I would just worry about chlorine and PH until your kit arrives.
As for your pool builder, I would look and see what is in writing for the warranty. I'm sure they see some owners do some stupid stuff, so they say things like you must keep chlorine feeder going at all times, etc. As long as you are testing on a regular basis and making sure your chemistry is in range, I wouldnt worry about it too much.
lauren_balty
4
San Antonio, TX
Yes, city water. I think I can see remaining algae around the skimmers and on some of the surface of the pool. The fresh water will hopefully bring the CYA low enough for chlorine to do its thing?
Thank you!
JJ_Tex
719
Prosper, TX (DFW)
So the algae comment is a new twist. As soon as you get your test kit, start the SLAM process which may take a few days. After that, maintain the proper FC levels per your CYA level.
Reactions: lauren_balty
ajw22
13,150
Northern NJ
You can add chlorine anytime during the day.
Take your water once a month to a "reputable pool company" get the test and file it and ignore it.
Do you have any test kit right now?
You want to raise your FC up to 5ppm once the water fills. That is 2 quarts of 10% liquid chlorine or 1 gallon of 6% liquid chlorine. Then add half of that every other day until you get your test kit and can do proper testing.
When you get your test kit post your test results and we can see what the next steps are.
Do you have PoolMath?
Have you read ABCs of Pool Water Chemistry?
lauren_balty
4
San Antonio, TX
I have a K-1004 testing kit. I'll go get some liquid chlorine ready.
I just downloaded the PoolMath app, and I have read ABC's of Pool Water Chemistry and I will continue to do so until I feel like really understand it. :)
