DoughBoy Sequel two filter bonding question
cabral255
Active member
May 28, 2015
27
Fall river
I believe my filter should be part of my pool bond but I can't find a place to put it on this filter. I know on Heyward filters they are easy to find. Also, someone told that filters don't need to be part of the pool bind but I believe they should be. Am I correct?
Teald024
The pic you provided shows a pump, not a filter. There is a connection to bond the pump motor. You may have to remove a cover at the back of the motor. You should check the owners manual. It will say where the bonding lug is located. Contact a qualified electrician if you have any doubts.
