Dolphin S200 tripping GFCI
Hootie
Active member
Jul 25, 2018
31
Medford, NJ
I have a fairly new S200 that I replaced an old pressure side cleaner about two months ago. Loving it until now. When I start it, it trips the GFCI outlet at random times but usually within two minutes of starting the cycle. I've replaced the GFCI outlet with no change. The outlet does not trip if the robot isn't running. Any ideas?
Hootie
Active member
Jul 25, 2018
31
Medford, NJ
So I made sure everything is dry and tried again. Still trips. This time I counted it off and it trips everytime right at about 38 seconds after I turn the robot on. Does something happen at that time point in the robot? I'm trying to be narrow down where the problem could be.
Hootie
Active member
Jul 25, 2018
31
Medford, NJ
Just to update anyone that encounters a similar issue, Maytronics replaced the power supply via warranty and it works just fine again. No GFCI issues. Thanks everyone!
