Dolphin Nautilus leaving black marks
KJB1
55
Temecula, CA
Recently got a Dolphin Nautilus and is doing a great job with cleaning but in a few spots where it gets extreme angles climbing steps or in a corner I can see where the black corner bumpers are leaving marks on our white plaster. Anyone had this issue? They don’t come off easily with a brush. Any hints on removal or prevention? I love not having to lug out the hoses and running the pump to use the suction cleaner.
cowboycasey
7,801
Southern OK
CircuPool SJ-40
I wonder if there is something you could put over the bumper to stop it??? Do you have a video or pictures of what is happening :)
vbertone
164
Arnold md.
I have the same problem, I just use one of those pumice or pumice like scrubbers and it comes off. But your right it’s not easy.
Reactions: KJB1
KJB1
55
Temecula, CA
Photos of the black marks. Looks kind of like a kid with crayon in these pictures. It’s not bad but is annoying for sure. It shows up better in person. I like stuff to be as perfect as possible for as long as possible. I notice that pine needle floating 😠
cowboycasey
7,801
Southern OK
CircuPool SJ-40
It does look like crayon marks... I am still trying to think of something that would stop it and nothing comes to mind... I will keep at it :)
Oly
2,125
Fresno, CA
I cant visualize this bumper you describe. Looking at pics of this model the plastic shroud is black, is that marking your plaster?
KJB1
55
Temecula, CA
The bottom corners have those black rubber bumpers.
Oly
2,125
Fresno, CA
Call Maytronics tell them you need replacements in white. If they are not available develop them yourself and sell them as an aftermarket upgrade for 4X cost.
Reactions: cowboycasey
KJB1
55
Temecula, CA
They are all black. Even different models, no other color options . I may try to just take them off or maybe first I’ll just put some clear gorilla tape over them and see how much abuse they actually get.
Reactions: borjis
cowboycasey
7,801
Southern OK
CircuPool SJ-40
Reactions: KJB1
KJB1
55
Temecula, CA
I did a easy test while it was out of the pool. I scraped the sides of the bot, the plastic as well as the rubber against concrete. Both came off really easy. I don’t know why scrubbing with a brush won’t remove it from the white plaster. Neither the plastic nor rubber really left a scuff Mark like black shoes in a gym on the concrete like I’m getting on the plaster. Very odd indeed.
KJB1
55
Temecula, CA
I found the Dolphin thunder is white but looks like same design for other counties. Tried to order the side panels from Marina pool. I hope they are available and can make them fit.
KJB1
55
Temecula, CA
I found they are pretty easy to remove with a scotchbrite pad. Not something you would want to do weekly but if your wife asking to clean them off like mine was.... I’m waiting on white replacement plastics from Marina pool still.
KJB1
55
Temecula, CA
Did some pretty extensive testing. It isn’t actually the black rubber but the plastic itself. I used tape then the white marine epoxy to make like a bumper. Used for a month or so with the epoxy and no marks. Outside the USA Maytronics sells them it other colors. Ordered the 2 lower trim pieces for one of those to retrofit. Had to trim the rubber on one side to keep it from getting stuck all the time. I guess that’s why from the factory they only have the rubber bumpers on one side. All seems good now.
