dolphin active 30i stops
jberrymd
19
edmond, ok
Hey...I have a Dolphin 30i and after 20-30 min it stops in the pool. I have cleaned the impeller and still happening. I had a problem with calcium flakes in the pool and used the Dolphin to clean so I wonder if there is calcium in the filters, causing flow issues? I have spent the afternoon with filters in MA and rinsing several times. Doesn't seem to be helping yet. Every time I put them back in acid I get a lot of bubbles so maybe I need to just keep repeating until no bubbles. Any thoughts?
cowboycasey
8,648
Southern OK
CircuPool SJ-40
This may sound crazzzy and I am not sure it will work.. Pull the filters and throw the robot back in the pool and run it.. Does it go past the 20 minutes and finish a cleaning? If so it is the filter.. If it continues get another filter and see if that fixes it.. :)
