Doing a renovation of my pool, trying to figure out what automation I should get
ibjames31
1
92131
Hello,
I have a pool with spa, no automation, no solar. I just upgraded my pump to a multispeed pentair pump, and will be adding solar, salt cell and automation. Since I'm getting my pool resurfaced I had a consultant say we can control our landscape lighting with our pentair system so it's adjustable via my phone. I currently do not have landscape lighting, so that is open.
My questions.
1. I'll have a pool pump, pool light, spa light, waterfall, solar heating and gas heater and associated diverters for pool/spa/waterfall
2. I'd like to potentially have lighting around the pool be the same color for the pool/spa and landscape around the pool (would this be expensive?)
3. I think I'll just have regular landscape lighting around the rest of the yard, not sure if it needs to be controlled by the pentair
What automation controller should I get? I'm trying to make sure it has options and isn't maxed out in case I want to add something in the future but don't want to overbuy.
How do I get all the lights to sync for pool/spa/landscape lights around the pool?
YippeeSkippy
17,551
Evans, Georgia
Hello! I am going to page the Pentair Guru guy here that is all up on automation. 🎶 paging @Jimrahbe 🎶
Welcome to TFP... hope you find all the answers and help you need here.
Maddie :flower:
Jimrahbe
22,854
Bedford, TX
James,
Did you upgrade to an IntelliFlo or SuperFlo VS??? It makes a huge difference depending on what pump you now have...
The Stock IntelliCenter can control all of these things.. Since you want to have a SWCG, then it makes the most sense to get the package deal.. This comes with the IntelliCenter, built-in SWCG power center, the IC40 or IC60 salt cell and two valve actuators.. you would have to buy another actuator for your waterfall...
The IntelliCenter can do that and yes, it will be expensive.. almost like buying pool and spa lights.
You can, if you want, have the IntelliCenter control your standard landscape lights.. (turn them on or off).
Here is a link just for reference...
