Does my skimmer "suck enough" (how much flow should there be)?
LearningAboutPools
Active member
Jul 4, 2021
39
Henderson, NV
Pentair Intellichlor IC-40
I really have no idea what my skimmer's performance should be.
There is definitely some water movement in the basket, but nothing "strong" by any means.
I attached photos.
Maybe my water is a little too low? It's never "run dry" in the basket.
Newdude
10,371
NY
It’s never really strong. The door closes and builds up pressure from the weight of the pool water. The water wins and knocks the door down which gently floods the skimmer and sucks in whatever is close by.
I agree the water looks too low for optimal skimming. Halfway up the skimmer mouth is the best level. I personally liked mine a tad higher in case some evaporated.
Reactions: LearningAboutPools
ajw22
27,887
Northern NJ
Pentair Intellichlor IC-60
Your water level is way low in the skimmer. The skimmer basket should be at least half full with water, if not 2/3 full.
You should not see any water movement when looking into the skimmer. The top water should be almost still.
Toss some ping pong balls into the pool and leave it for a day. If the ping pong balls find their way into the skimmer then it is working properly.
I can see a bunch of leaves and pine needles on the surface of my pool. If I stand there I never see them go into the skimmer. But if I came back the next day the surface is clean and the skimmer basket is full of stuff. Skimmers work like subs, slow and silent.
reggiehammond
333
Fort Worth, Texas
CircuPool RJ-60 Plus
If you hold the weir door up, I think you'll see that the basket goes dry fairly quickly. I think your water level could be a touch higher - but do you have a concern or are you just curious? I've turned my main drain line basically off, only open the smallest amount, which forces all the suction to the skimmers. Performance has been way better and it's collecting 99% of the debris on the pool surface.
LearningAboutPools
Active member
Jul 4, 2021
39
Henderson, NV
I toss tennis balls into my pool and they tend to end up in the skimmer, as do my pool noodles if I don't take them out and put them away at the end of the day.
Thank you for all the feedback!
I have the Pentair infloor system so I need to leave my main drains open as well so that they can suck down all the junk pushed at them.
LearningAboutPools
Active member
Jul 4, 2021
39
Henderson, NV
*forgot, No I don't have any real concerns I was just wondering about it.
When we finished the build and filled the pool we had to chisel out some mortar and junk that had dropped into there and blocked the door from working properly.
Ever since then I always sort of wondered if I got everything right or if maybe there were other issues and I needed to address the flow rate.
proavia
2,459
Chandler AZ
Ideally, your pool water level should be about 1/2 way up the height of the weir door (when door is closed fully). Yours appears about 2" or so too low.
