Do these numbers look okay?
JHUB
Active member
Feb 16, 2021
35
San Diego
Pentair Intellichlor IC-40
Hi All,
First time pool owner, We just finished the pool about 2 months ago and since then I have been trying to balance the chemicals, I do not want to hire a pool company to maintain. Do the numbers below look okay?
Build Type: Plaster
Volume: 12000 gallons
Latest Test Result Summary:
FC: 6.0 (yesterday)
CC: 0.0 (yesterday)
pH: 7.8 (yesterday)
TA: 90 (yesterday)
CH: 375 (yesterday)
CYA: 40 (yesterday)
SALT: 3400 (yesterday)
TEMPERATURE: 84° (yesterday)
CSI: 0.17 (yesterday)
John
Texas Splash
41,583
Fiberglass
CircuPool RJ-45 Plus
John, overall they do look good. The CYA is a bit low for a salt pool, we generally recommend about 70 minimum. So if you see the pool having difficulty maintaining FC, you might want to increase the CYA a bit. See FC/CYA Levels.
When you get a chance. also add your test kit to your signature. :)
JHUB
Active member
Feb 16, 2021
35
San Diego
Thank you!
JHUB
Active member
Feb 16, 2021
35
San Diego
Is there any risk to adding too much CYA? Will adding more CYA increase my salt level as well?
Texas Splash
41,583
Fiberglass
Too high is a risk in any pool (90 or above), but with us salt owners, a CYA of 70 is recommended. If you're concerned, you can go in 10 ppm stages to slowly get up to about 60 and monitor the FC resilience to the sun. Adding CYA won't change your salt level.
Reactions: JHUB
