- Sep 18, 2020
- 47
- Plaster
- Jandy Aquapure 1400
Setup - 14 year old inground pool, approx 45K gals, gunite with plaster, spa waterfall into pool, 3 skimmers and main drain for suction, 2.5 HP Hayward Energy/RS pump, all valves/filter/lighting/heater are Jandy... all skimmers and main drain have separate shut off valves at equipment pad
It appears I have 2 skimmers that have sub-terrain leaks - when either is open, I am getting significant air into the pump and of course back into the return lines... when I close off both, I have no air, but that leaves me with 1 skimmer and the main drain for suction... looking for thoughts on what else I should test with those 2 skimmers? any value in getting a submersible camera down there to verify what may be the issue? any other place I should check, like sub-terrain at the equip pad as well? if indeed it is a skimmer(s), is that a doable DIY job?
thanks...James
thanks...James
