Diving into SWG -- need layout advice
dntboles
79
Boerne, TX
I've decided I'm tired of lugging cases of chlorine, once I find it for sale, from the store to the van, then van into the garage then to the pool and doing my best to avoid more bleach spots on clothing while pouring it. I haven't had any crazy green algae, but it got cloudy a few times in less than a year.
I have an IC-40 with associated bits and pieces on order. I understand the basics of where it should go, but when I look at my current plumbing, there just isn't enough free pipe between things to cut and reconnect anything. It seems I'm going to have to cut way back to before my spa/pool valve and replumb that entire section. Does that seem right?
Here's what I think so far:
1. Cut bottom pipe coming out of heater, then 45 it to the left (back) sooner, to give me a little more depth to work with later.
2. 90 up to vertical
3. 90 toward front
4. Do I need a check valve before the IC-40? If so, I would add a flow meter/check valve here
5. IC-40
6. Pool/spa valve -- looks like I'll need an all new valve base
7. 90s off pool and spa sides
8. Booster pump somewhere in here, on pool side
9. 90 down
10. straight coupler down
Does that all make sense? Advice?
Is the height of the entire horizontal section critically important? In other words, when I cut the front vertical over the pool/waterfall valve I will need to either lower everything or add a coupler to lengthen the vertical, back to the same height before the 90, resulting in close fittings with not much room left if this ever had to be recut again. However, if I could cut just below the current 90, then put the coupler there, it would raise the horizontal sections a few inches.
Thanks for your help and thanks to @ajgraham for sharing some of the details on his adventures into SWG. He and @Jimrahbe have answered some other questions for me.
Reactions: ajgraham
ajw22
29,132
Northern NJ
Pentair Intellichlor IC-60
I would do 3 cuts where the red lines are and remove the POOL/SPA valve and actuator and the CV and chlorinator.
Relocate the POOL/SPA valve and actuator to the front of the pad. Then you have a nice run to put in the SWG.
The SWG does not require a CV before the heater. But while you are in there you may want to install a heater bypass that would include a CV.
dntboles
79
Boerne, TX
Got busy with other stuff for a while and coming back to this. If I only add SWG now (and defer heater bypass to later), do I need to have a check valve in there somewhere?
PoolGate
6,493
Damascus, MD
Jandy Aquapure 1400
Check valves are used after the heater and before chlorine puck dispensers because with low or no flow the chlorine could backflow into the heater. With a SWG, it only produces chlorine with adequate flow so with no/low flow there is no chlorine to backup into the heater. Hence the check-valve isn't needed.
dntboles
79
Boerne, TX
Thank y'all! It seems the transformer I need is out of stock. I've got the other electronic components on order to go inside the EasyTouch box.
dntboles
79
Boerne, TX
Electrical components installed. Now I'm working on the layout. The SWCG part would have been simple, but adding the heater bypass complicates it a little. The dark grey straight part is the SWCG, with 12" on straight section before it. The disconnected T is for the booster pump.
Reactions: HermanTX
PoolGate
6,493
Damascus, MD
Jandy Aquapure 1400
For the record, I am not a fan of heater bypasses. It simply allows water to sit in the heater and go stagnant. I had water go stagnant in my umbrella sleeves once that are on my sundeck below the waterline from leaving the cap on. It stinks the whole pool area up. I see no reason for a heater bypass. With properly balanced water your heater should not have an issue with water running through it 100% of the time. They are designed for that.
Newdude
11,239
NY
+1. My water went through my heater for 8+ years. Now, had I needed to remove the heater due to a problem, that may have changed my opinion, but I also would have been able to make my own straight pipe / backwoods bypass for the short term so probably not.
I wholeheartedly agree that they can greatly come in handy but weigh that out that most will never actually need it.
dntboles
79
Boerne, TX
Version 5. My original version had 8x 90-degree turns from the supply pipe to the SWCG. This has 3. I'm up to 5 beers earned.
I appreciate the inputs on pros and cons of a bypass. If I didn't already have it torn apart, I wouldn't just add a bypass right now. I may decide later to not use it, but I already have the plumbing cut up to install the SWCG so I'm going to install the bypass now. If I decide it's not a good idea, I could just not use the bypass.
Sketchup Pro trial version comments: It's not intuitive, but there are plenty of YouTube videos on how to use it. You can download components such as the heater, valves, PVC and filter. Some folks have the talent of being able to envision the best layout, in 3D, in their brains. I don't. I sketched the layout on paper, but just couldn't see the 3D concept to figure out what would fit where. By creating the 3D model, I am able to test the fit before going out to make the cuts. The bypass valve is in a tight spot. If needed, I can move the SWCG and pool/spa valve toward the pool side a little.
Reactions: nobody291
Newdude
11,239
NY
Absolutely!! If you ever need it, it will be worth it’s weight in gold. There is no argument whatsoever that it may come in handy.
Just like CYA, we round up. So that’s a sixer. Always round up to the next 6. :ROFLMAO:
Reactions: dntboles
dntboles
79
Boerne, TX
Well if I'm required to round up to 6, then here's version 6. As I went out and actually started dry fitting the pieces, the plumbing spirits smiled on me. Turns out I don't need the extra depth, so I could remove some 90s and simplify this even more. Then there was the thunderstorm warning, 2" of rain, tornado watch... it was a good time to come inside.
dntboles
79
Boerne, TX
Plumbing done. It's time to open the first beer. Next will be sometime after system pressure check, when I put in the SWCG and clean up the wiring. Third will be after the salt level is correct to start up the SWCG. Fourth after it's producing the appropriate level of chlorine. Fifth will be when I realize I normally would have been adding liquid chlorine but don't have to do so. Sixth will be when the first person notices the water feels different.
dntboles
79
Boerne, TX
I was concerned someone would turn on the heater while the heater bypass was activated. One option involved buying a valve actuator and installing it. Instead, I locked it out and tagged it.
