Distance required between top of skimmer gasket and pool liner track?
hockeytommy84
17
Ontario Canada
I am in the process of setting up my skimmer on my concrete block pool build. What's the minimum or suggested distance I leave between the two (top of skimmer plate and liner track) on a vinyl liner install? It's top mount track fyi.
jimmythegreek
In The Industry
Aug 10, 2017
3,368
Morris Cnty NJ
It's to leave a little meat on the liner between them and leave room for the faceplate trim. Usually kits have them pre cut not sure where ur panels come from. If u gotta cut yourself make sure you test the trim plate so theres an inch of liner showing or it wont look right. The extra inch wont matter I get your angle. I cut them high too I like water as high as possible to coping it looks better
