Due to some heavy rains this winter and draining off excess water, my CYA level has drifted down, now at 23 ppm. I plan to bring it back up to 40 with dry stabilizer, but I’m wondering how water temp will affect disolving the CYA using the sock method. Should I wait until temperatures rise and the water is warmer? The current water temp is 52F and I’d rather not heat the pool until the Spring.
It’s a plaster, in-ground pool, all other chemistry has been stabile.
Thanks in advance for any advice.
