Display on pentair VSP is completely out. Installed in 2013. Filter pump and Booster are tripping. 3 weeks ago had similar issue where I was losing communication and system would fail, but display screen had power and I could get it running in service mode, but would trip . Had a service tech over and cleaned ants nest from panel/ boards. Has been working fine until last weekend. Technician said if pump goes down again that I’ll probably have a bad drive and to replace pump. I opened the electrical box and found tons of black ants crawling around the wires and boards again. Cleaned out but still no power coming to pump. Question is do I have a bad pump or could the electrical/ boards be damaged from ants and affecting power to pump? Thank you, Dan
