Disable Intelliflo VS Priming Mode
Rancho Cost-a-Lotta
1,425
Rancho Cucamonga, CA
My pump primes at max speed, which is set somewhere around 3200 RPM. I want to maintain the higher speed for use of the spa, so I don't want to mess with the max speed setting. Priming at this speed seems like overkill and probably unnecessary.
Yesterday, I disabled priming mode and tested things out. The pump is set to start at about 1600 RPM, then bumps up to 2500 RPM for a couple hours. Disabling prime mode doesn't seem to have any negative effects.
With a closed system, what's the purpose of prime mode? Is there any reason I need enable prime mode?
ajw22
16,251
Northern NJ
Not all closed systems are perfect and hold pressure and some pumps are above the water level. Rather then having a lot of service calls it is easier to just set the pump to always prime.
If your system holds prime then you don't need it.
