Dilute -100F antifreeze or use less?
Diver
477
South of Boston
The store didn't get enough of my regular -50F RV antifreeze, so I got a couple more bottles of -100F RV antifreeze.
The ingredients are the same, so I assume it's safe to mix and use.
But I'm wondering if it would translate into 1:2 ratio.
Meaning, can I make 2 gallons of -50F antifreeze out of 1 gallon of -100F one by adding water?
It would be helpful if list of ingredients had %% in it, but it didn't.
I assume it's ok to pour less or -100F antifreeze into pipes instead of diluting and making it -50F?
Newdude
7,954
NY
Look up the active ingredient and its freezing charts as there are a few kinds. Most of the common ones have a dillution point where they drastically lose efficiency with a stronger concentration. It would be hard to guess how much water is left in the pipes to know the exact mixture %, but several charts did not equate half strength to half the degrees of freezing.
If its the same $4 a gallon as regular antifreeze, is it even worth it for $2 ?
