Different Test Results
RMcGirr83
936
Tuscola, TX
So for my own edification, which is now driving me completely insane, I've been doing some tests using various methods of testing:
  1. Lamotte ColorQ 7
  2. TF100
  3. Pool Store (BioGuard)
What I can't understand is how the results can be so completely different. I can understand a 10, 20 ppm swing but some of these numbers are just crazy. The below were all done within 5 minutes of each other
Basically the TA and CH numbers vary greatly which, naturally, is affecting my CSI number. CH I'm not too worried about but I'm trying to dial in TA so my pH is more stable. Why aren't these more in line?
Lamotte Color QTF100BioGuard
FC2.42.02
CC000
pH7.67.87.8
TA649047
CH376850544
CYA506071
CSI-.10.63"High" whatever that means
ajw22
19,790
Northern NJ
TFP recommendations are calibrated to Taylor reagent testing.
Different testing methods give different results. If you developed a set of recommendations for the Lamotte tester or a specific pool store you would fit it to their testing results.
You have proved again why only Taylor testing is recommended for following TFPC methods.
Reactions: Arizonarob
proavia
1,971
Chandler AZ
Rich, you've been around here long enough to know we don't hold pool store test results in high regard.
When doing the TF-100 tests, are you holding the reagent bottles perfectly vertical and allowing the drops to fully form on the tip (not forcing the drops off the tips)? Are you using a speed stir?
Also, what is the CH and TA of your fill water?
RMcGirr83
936
Tuscola, TX
Yeah I know not to trust pool store stuff and yes I am holding bottles completely vertical for both TF100 and Lamotte. Haven't tested my full water lately but last I recall CH was 225ish (Texas water is harder than diamonds) and can't recall what the TA was but will test it again from off the irrigation system which is before going into the house (autofill is hooked into irrigation line).
This was more of a "let's see what's what." I just can't fathom the CH results would be off that much.
proavia
1,971
Chandler AZ
How long ago was the pool filled completely? What is your evaporation rate?
Here in AZ, the water is hard also. CH around 250 and TA of 110. With evaporation rates in AZ, my CH at least doubles every year.
RMcGirr83
936
Tuscola, TX
Pool was completed in November 2018. No idea what the evap rate is but have to imagine it's pretty high given the 95+ temperatures, wind and low humidity.
proavia
1,971
Chandler AZ
With a fill water CH of 225ish, your entire pool would have had to evaporate more than 3 times since November 2018 to get a result of 850 on the TF-100 CH test. It's doubtful that that has happened. Are you hand swirling or using a speed stir?
Using a speed stir, my CH readings dropped about 200ppm over hand swirling.
proavia
1,971
Chandler AZ
Well, it sounds like you are doing everything correctly with the TF-100 CH test. Have you tried the test again to see if the results match the previous test?
Do you happen to recall what the CH was in November/December?
If you have not added any calcium to the water, going from 225-ish to 850 in 8-ish months seems excessive though. Let's see what others might have to say.... @JoyfulNoise @mknauss
RMcGirr83
936
Tuscola, TX
I'll do it again today when I get home but so far the two I've done on two separate days were pretty much in the ball park 30+ drops to get the vial to change color
JoyfulNoise
Platinum Supporter
May 23, 2015
17,284
Please dilute your pool water sample 1:1 with DISTILLED water and retest. Start the test by adding 5 drops of R-0012 FIRST then add the R-0010 as-directed. Add the R-0011L dye, then titrate with the R-0012. ADD ALL DROPS OF R-0012 TOGETHER. Please report back the result.
RMcGirr83
936
Tuscola, TX
15 drops of R 0012. 5 at onset, 10 titration
JoyfulNoise
Platinum Supporter
May 23, 2015
17,284
So 15 x 25 x 2 = 750ppm
Given the inherent inaccuracies of diluting without the proper chemical gear, I’m going to say your 850ppm CH is probably correct. The LaMotte ColorQ only has a range up to 700ppm and they can be very, very off when it comes to CH tests. I’m inclined to believe the Taylor tests because the process used is more accurate. The ColorQ uses absorbance to detect concentration and that can be very tricky to get right.
