Difference between Liquid and Granular Stabilizer (CYA)
Esloser
513
Millville, NJ
Is there a difference between the liquid stabilizer and the granulated in a sock in front of a skimmer squeezing every so often CYA?
triptyx
1,495
Yes, cost. ;)
Other than the granular taking a bit longer to dissolve out of the sock (frequent massage of the sock is the answer), it's just as effective as the liquid and at less impact to your wallet.
Patrick_B
14,999
Midland TX
Just the cost. The liquid is double the money or so. Not really worth it. Of course, the liquid you don't have to put in a sock.
Sorry Trip and Esloser, we posted same time nearly.
Esloser
513
Millville, NJ
Is there any difference in absorption rates? I think I read on here somewhere that CYA takes a week to show up in testing? Is that true for both?
triptyx
1,495
No, the information about waiting a week is old and needs to be updated.
Once you have massaged the sock and all of the CYA is out of it, you're good to measure CYA almost immediately. Personally, I wait overnight, but you definitely don't have to wait a week.
The liquid you can measure about half an hour or so after adding it, assuming you added it in front of a return and the pump has been running the whole time.
Uncle Salty
241
South Carolina
If you go with liquid make sure you shake the heck out of the jug before and during while pouring as it has a tendency to come out clumpy and requires lots of additional brushing, though some bottles are better than others for this issue. Also dunk the jug into the pool water and shake to make sure you get it all out.
Salty
Patrick_B
14,999
Midland TX
This is true for neither. The forum used to say this to cover all bases of application methods and variances that were sometimes thought to exist. Once Cya is completely dissolved and the pool has time to circulate a little while, you can see it on the test.
Salty
Yes, it does separate and get all clumpy in the bottle.
