All dichlor would be sodium dichlor, else it would be called trichlor, which is what the pucks/tabs are made of. Dichlor has a sodium atom in place of one of the 3 chlorine atoms that trichlor has. I'm sure that dichlor can be tabletized, but the point of it is to have a quick-dissolving form of CYA stabilized chlorine. The only advantage to dichlor tabs that I can think of would be that it is nearly pH neutral. There are 2 types of dichlor (anhydrous and dehydrate) that have slightly different available chlorine levels, but both are sodium dichlor which has CYA.
