My pool opened May 1, 2019 for our first swimming season (pool as completed Oct. 2018). Since opening our FC would continually drop to 0, we followed recommendations of our pool store and pool builder who had us shock our pool constantly, boost our SWG, only to have FC consistently drop to 0. as CYA climbed to 80, FC at 0 and water with a green tinge last week I finally took matters in to my own hands and came here desperate for advice. Thanks to you all our water was beautiful and at appropriate levels (held FC loss at 2-4ppm through the weekend with daily testing and bleach added) for us to enjoy our Memorial Day weekend. Based on forum recommendations I went and got Liquid Chlorine 10% and have been using our pool as a liquid bleach pool as opposed to a SWG pool. My test results from last night are as follows:
FC 4 (added liquid bleach last night to bring to recommended level of 8 per Pool Math, didn't test again last night but did test this morning and it was 9.6)
PH 7.6
TA 125
CH 175 (working to increase this)
CYA 70 (we were at 80 last week due to all the shock etc. we'd been told to add. I believe we're around 70 now as we've been lowering water few inches and adding fresh water as we can)
Salt 3500
SWG set to 40%
The pool builder is trying to get out to check the SWG but they are adamant they think it's working, but I've yet to be able to get it to produce FC needed to keep pool at safe levels, but this is also all very new to me. They also currently can't even fit us on the schedule to come out so I'm curious now, if there's a way I can test to see if my SWG is working? I'm currently keeping FC rather high since for bleach pool our CYA of 70 and 80 (last week) requires higher FC levels.
My thought was I would test water this afternoon, add chlorine as needed (to bring to proper bleach pool levels for CYA), adjust PH if needed, but leave everything else alone and increase my SWG %. I'd test FC once sun went down and test again in a.m. before sun comes up and see if FC increased over night. If so, then my SWG is working, right? At which point I'd work to get my numbers to SWG numbers as opposed to Bleach numbers which would allow me to operate at lower FC levels for my CYA. If I do this, how long after I add chlorine tonight, should I wait before doing my FC test this evening? Will having my numbers not ideal for SWG affect whether this shows me if my SWG is working or not (like I know my TA is too high, should I lower that and then try and figure out if SWG is working?) Any advice on how you all would approach this and/or test is greatly appreciated!
PH 7.6
TA 125
Salt 3500
SWG set to 40%
