Debating between replacing motor or buying complete new VS pump
JCJR
273
Miami
My Jandy 2.5hp 2 speed pump (14 years old) just crapped out. Took it to a electric motor repair shop and they said can't salvage. A new 2 hp motor will run $400 plus new seal and tax. Repair guy said the motor really isn't 2.5 hp.
Should I replace the motor or bite the bullet for a new pump seeing that the pump housing is old. I ran the pool on low speed 100% of the time only using high when turned on water features and/or solar. The low speed barely ran my suction vac so I bought a Robot (Explorer E30) last week before pump gave out.
If I go with new pump, which one? Are there any offers right now?
cowboycasey
8,524
Southern OK
CircuPool SJ-40
You could do both :)
If the pump is not too old and still works, pumps water and has no air bubble in the lid when running you could grab a V Green VS pump and connect it up and be good..
You could also get a whole new VS pump..
I am almost positive it is a square motor.. Call inyo and make sure you can use this one.. Also get a new Salt or SCS seal with the rebuild kit..
  • Use-The-Right-Seal-For-Your-Pool-and-Spa-Pumps.pdf
