Hi
I'm after some advice on how to lower my ph levels in our vita prestige hot tub when dry acid doesn't seem to touch it.
Our main water ph is over 8 heading towards 8.4 before I start but Alkalinity isn't not high. We're in a particularly hard water area to.
Drained & refilled just over a week ago as cynuric acid levels were high & was due to be changed anyway.
Chlorine floater tablet dosed
Alk reading being maintained around 100
Tested with a Photometer & test strips
Tried many failed attempts with ph minus/dry acid to mostly no availl if I do get it down or wipe out as soon I re balance the alkalinity I get ph bounce. Just so frustrating when I can get everything else within recommended range minus the ph,
Can't be adding ph minus every other day!!
Would muratic acid work better & where do I buy in the uk/what strength etc? or any other suggestions welcome.
