DE valve leak
tcat
1,318
Austin, TX
CircuPool Edge-40
The gauge/release valve on top of DE filter doesn't fully shut off. Is there a gasket I can replace, or do I need a new valve?
tcat
1,318
Austin, TX
CircuPool Edge-40
Dripping from the air/water nozzle. I found a post about taking it apart and lubing the orings. It's 15 years old, so may need new orings. Wonder if there's a lot number. Leaking slow.
Jimrahbe
27,029
Bedford, TX
T,
If it is leaking out, where the water/air normally come out, then it most likely just has some debris in the way. You can often force water back into the open valve (pump off) to force the junk back into the filter.
ajw22
37,884
Northern NJ
Pentair Intellichlor IC-60
tcat
1,318
Austin, TX
CircuPool Edge-40
Thanks. I ordered that one just in case lube doesn't help. 15 years in Texas sun, I doubt if o'rings are in one piece.
ajw22
37,884
Northern NJ
You order it from that Amazon link? I looked at some reviews and a few folks said they didn't get an original Pentair part.
jark87
941
Flower Mound, TX
Jandy Aquapure 1400
I purchased a Hayward relief valve on Amazon and got original Hayward part. I think the oring was going to cost close to $10, but the whole valve, including oring was only around $15.
