DE in pool
michaelbuday
Active member
Mar 1, 2017
25
Dana Point, CA
Pentair Intellichlor IC-40
One of my Pentair Quad 80 filters separated, the pleated filter material just gave way, sending a lot of fresh DE into the pool.
I replaced all the cartridges (10 years old) and added about 8lbs (of the 12lbs recommended) and restarted the pump. My logic is that at least 4lbs of DE is
When the DE settles to the bottom, the pool is crystal clear, but attempting to vacuum the pool floor has been futile. All the returns are on the floor of the pool and send the settled DE back into the water.
If I just keep the filter pump running for a couple of days, will the DE finds its way back to the filter and stay there? It seems to be clearing up after a few hours now, but wondering if this process makes sense!
Jimrahbe
21,276
Bedford, TX
Michael,
Keep the pump running and keep sweeping the DE up so that it will eventually get sucked into the skimmer.. another option would be to run your pump off of just the main drain and then sweep the DE into the drain.
I foresee you doing this several times...
michaelbuday
Active member
Mar 1, 2017
25
Dana Point, CA
Michael,
Many thanks Jim. Yes - I anticipate a long weekend of pool “fun.”
Jimrahbe
21,276
Bedford, TX
@michaelbuday
Do you normally backwash your Quad DE filter??? We have been told by several users to just open and clean then once or twice a year works better.
Also.. These filters have a habit of being installed backwards, which is not apparent at first.. Not until a cartridge explodes..
Show us some pics of the damaged cartridge and any part numbers you can find on the Multiport valve...
Candurin
247
South Jersey
Fiberglass
I replaced all the cartridges (10 years old) and added about 8lbs (of the 12lbs recommended) and restarted the pump. My logic is that at least 4lbs of DE is...
Just FYI. The Quad DE 80 uses 8lbs total of DE, not 12.
michaelbuday
Active member
Mar 1, 2017
25
Dana Point, CA
Well that will teach me not to look at the “guidelines” printed on the box of DE! I should have known better and consulted the operating guide for the filter.
Thank you
Candurin
247
South Jersey
Fiberglass
Thank you.
My pleasure. That may also explain some of the additional DE showing up in the pool. Can be a result of overfilling.
Jimrahbe
21,276
Bedford, TX
Michael,
Did you see my post #4???
If your pool builder used the wrong MPV valve it pushes water backwards through the cartridges..
If you will post the MPV part number, we can tell you if it is the correct one.
This has happened a few times...
