Yep, that's exactly what Jim and I suspected. So there really are two possibilities at hand:
1 - After 3 years or so, your grids are getting coated with oils and such that are beginning to effect filter pressure that simple backwashing can not correct. Or .....
2 - You have the on-set of algae beginning. It is very common for algae to not be visible to the owner in its early stages. The first indication of algae is almost increased filter pressure, followed by cloudy water, then eventually the dreaded "green".
I would recommend a couple things..... First, post a full set of test results with your K-2006 so we can see exactly how the levels look. In addition, it's easier to do an
Overnight Chlorine Loss Test before tearing down the filter, so I'd do the OCLT as well. If you pass the OCLT, then you may need to look at any options to deep clean those grids.
Maintaining your swimming pool filter system is important. Learn how to clean and maintain your pool filter at low cost & enjoy a Trouble Free Pool.
www.troublefreepool.com
