So my pump broke down in July and I had an emergency and couldn’t return until now. I had just cleaned out the DE filter - but the shaft seal was bad.
Anyways when I returned the pool was a swamp. I got someone to replace the shaft seal and the pump is going. I was having to backwash every 2 hours, then every hour, then30 minutes.
So I opened up the filter (Hayward 6020 DE filter) and the grids didn’t look that bad actually but I hosed them down and put it back together. I did notice that when I would open the valve up top to bleed air out of the filter water would dribble out rather than shoot out (this was before hosing off and after)
Once reassembled the psi instantly goes to 20 and climbed to 30 in a matter of about 90 seconds. I shut it off and added more DE and it remained steady at 20 for about 10 minutes and then started to climb by about 2 psi every 5 minutes or so.
Currently the pool is on recirculate to at least keep the chemicals moving. There’s no surging and when I first started the filter and for the first day there wasn’t this constant climb. So I don’t think it’s a return line clog. Circulation is good even when it’s on.
Before all this when I’d bleed air the water would shoot out and I’d close the valve - but now it still just dribbles. Is it a bad gauge or air tube possibly? With all the algae maybe I need to stop and wash down the grids with tsp? I was thinking with all the filtering I’d just hose it down every couple of days and do one final breakdown and deep cleaning - but maybe I need to do more.
