May seem simple to figure out but I’m perplexed ! I Darn down my pool system for the winter 1.5 months ago. We’ve had a warmer than usual winter in my region. I’ve notice lots of algae and lots of leaves / Crud in the bottom of the pool. I cleaned out the leaves , super shocked the pool, cleaned my Hayward DE 4820 and scrubbed. I did not add DE. Started my system up and running full motor strength in hopes to clean up the murkish green water back to normal. I noticed the pressure gauge going to 30-40 psi! So I backwashes it and it went back down (note water was not “dirty” but normal water coming out). I started it in the proper filter mode again and noticed after an hour or so it is back up to 20-30 psi! I’m like what the heck. Could it be the algae is getting pressed through the pool filter and causing the pressure to raise. ? Maybe I should run my motor at a lower speeds to filter more efficiently? Maybe I should add the DE? What’s your 2c?
