De filter issues maybe?
mknauss
26,368
Laughlin, NV
Very plausible.
Do you have a multiport valve? If so, set on recirc and follow the SLAM Process. If not, take the grids out.
After you have a blue and cloudy pool, then when you have time start filtering out. You will backwash alot.
Gail/Dave
33
Brook Park MN
thank you I now have the filter on recirculate as suggested.
this is what I’ve done to date. I have been slamming for over a week.
CYA at the beginning of this time was 50 after repeated filter cleanings and topping water off its at 40.
FC has been between 15 and 22
PH Between 7.2 and 7.5
TA 140 CH 75
We started out with the DE filter then changed to a sand filter because it was clogging up so bad now we are back to the DE filter because the sand filter is doing. We have a single speed motor. Any thing else I should be doing? Or do I just need patience??
Also I have been brushing 3-4 times a day. Pretty sure we have most of the leaves and pine needles out. Again thanks for the help
mknauss
26,368
Laughlin, NV
Stay at it. Any debris in the pool is slowing the progress. Can you vac to waste? Might be worth a try if you believe there is still material in there. Otherwise, test FC and raise back to SLAM level a few times per day.
