Damage from saltwater in Pool
march2012
468
TX
Moved from here.
What your PB is saying has no scientific basis that a pool st SWG salinity is any more damaging to a natural stone then a non-salt pool. And the kicker is that if you use Liquid Chorine, that has salt in it, in about 2 to 3 years the salinity will be the same as a SWG pool. Does your PB tell you to worry about that? Nah!
This has become the mantra on this forum, yet there is plenty of scientific evidence that ocean water concentrations of salt destroys stone.
The experiment showed that the greater the supersaturation, the greater the salt's destructive potential. Temperature also played a role: in cycles in which the temperature never fell below 25˚C, it took an average of four cycles before damage occurred. When the temperature dropped to 3˚C, one cycle was enough. "Although these wet and dry cycles play a part, supersaturation is the most important factor," explains chemist Caruso.
For a building, this means that if environmental conditions are such that a salt solution repeatedly infiltrates porous stone and the fluid can then evaporate again (e.g. due to strong sunlight or wind), the salt in the building material can become supersaturated. "In these cases, it doesn't take a lot of salt to inflict considerable damage," says ETH professor Flatt. However, higher amounts of salt are needed in more moderate environmental conditions.
PoolGate
5,557
Damascus, MD
Jandy Aquapure 1400
Saltwater pool concentrations are 3 parts per thousand. Ocean saltwater concentrations are 35 parts per thousand. HUGE difference!
Newdude
6,871
NY
And the building materials / locations being discussed are pounded 24/7, like the pilings under a bridge. Occasional splash out is a joke by comparison.
march2012
468
TX
There are plenty of examples of buildings and statues that are only exposed to salt air or salt via rain. I didnt bother to post all the literature, just one summary study to emphasize the point that there is data that specifically shows that salt can destroy stone. Concentrations, temperature, time periods are all important.
This study used 6% and 2% concentrations (sodium sulfate, not chloride). this is roughly 15 times and 5 times the normal pool concentration of salt.
From
This damage caused by salt is not seen only on historic buildings. It is also a problem for wall paintings, such as Michelangelo’s frescos inside the Sistine Chapel in the Vatican, says Caruso. These can be damaged by salt efflorescence in the stonework or the paint layers or in between.
The researchers are now planning to use their findings in a project in Havana’s old town, where salt is a major issue. The special render used in restoration work crumbles away from building façades after just a few years, and the aim of the research project is to discover the exact cause.
Newdude
6,871
NY
It can. And it does. :) But nowhere near the short timeframe of a couple of seasons that people report their patios weathering when blaming the salt pool. A lifetime ? Sure. 25 years even....... but not 2 years.
Reactions: Donldson
PoolGate
5,557
Damascus, MD
Jandy Aquapure 1400
From
Those percents are actually 20 times and 7 times, but I get your point.
What you aren't taking into account is that saltwater pools and non-saltwater pools have roughly the same salt concentration after a few seasons. 2-3 parts per thousand. Everything you add to a pool chemical-wise adds salt. This includes chlorine and muriatic acid, the 2 most common additives. So to say saltwater pools are bad and "non" saltwater pools are not is a stretch. It should make one wonder of the reasons for the misrepresentation.
The main goal of those that poo poo saltwater pools due to the "destructive nature" of saltwater is to sell you an alternative system like Ozone, UV or mineral systems. Always look at the ulterior motives. Do your research and choose the system you feel the most comfortable with.
This site is a non-profit entity run by pool owners with no profit to be made by selling you pool care products. There aren't even any ads on the site. TFP is not a "general discussion" site about pools and what what one individual likes over another. TFP endorses 1 style of pool care and is dedicated to disseminating that proven method. Other methods are out there, but they are not the point of this site, and hence why this post was moved.
pjt
281
The Woodlands, TX
Pentair Intellichlor IC-60
All pools are salt pools to one extent or the other. My liquid chlorine pool (non-SWG) had a salinity of 4,400 before I did a partial drain and fill. OBTW, there was zero indication of any sort of salt damage anywhere.
zea3
13,058
Houston, Texas
Water without salt is also destructive. Beautiful canyons have been carved into stone by centuries of river erosion.
Reactions: Bperry
YippeeSkippy
16,000
Evans, Georgia
That study should have used sodium chloride.
As we know, sulphates build up and destroy cement over time..... so we don't endorse the use of sulphate products such as "dry acid" in TFP pools.
