Cyanuric Acid Too High According to my Store App But...
Lucky13F
21
Basking Ridge, New Jersey
Pool is Crystal Clear -- and I want to Keep it that way! :)
Please take a look and let me know what you guys think I need to do -- if anything.
The app I am using -- naturally --- tells me to "go into the store for more info"
Using Store App to Log Results. I am not sure if it's ok to mention the store by name -- so I will not.
Test Kit is AquaCheck 7
Here are the readings - They are my best estimate based on comparing the color:
Free Chlorine: 5
Total Chlorine: 10
pH: 6.6
Total Alkalinity: 140
Total Hardness: 250
Cyanuric Acid: 85
Total Bromine: 20
ajw22
19,685
Northern NJ
Smart decision to stay out of the Pool Store. According to TFP guidelines with a CYA of 90 your FC should be 9-11. See FC/CYA Chart
The CYA is on the high side and you either need to drain 50% of your water to cut your CYA in half or run at higher FC levels. See Draining - Further Reading
Unfortunately your test kit cannot test FC at higher levels. We recommend you get a better test kit, either the TF-100 Test Kits or the Taylor K-2006C.
I suggest you read ABCs of Pool Water Chemistry
