cyanuric acid correction to total alkalinity
Bozer4
Active member
Jul 11, 2019
36
Manteca ca
I have a Taylor K2006 test kit and their test and treatment guide has a Table N for cyanuric acid correction to total alkalinity.
See water test below.
FC 6.4
PH 7.6
TA 80
CH 260
CYA 40
I am in the lower acceptable range for TA at 80 ppm, however if I use their formula I am lower than the desired range. Carbonate alkalinity=TA-(CYA x .33) which equates to 80-(40 x .33). This puts me at 67 ppm. Does Troublefree pool use this table? This is new to me. Thanks for your help and sorry about the large image.
frogabog
2,833
Portland, Oregon
Taylor and TFP are not synonymous.
TFP is much simpler.
I suggest that you disregard the booklet, and read ABCs of Pool Water Chemistry.
And further information in Pool School.
Additionally, Pool Math does your calculations for you. If you prefer, you can use the browser version of Pool Math. (I like it for some things, although the app does calculate most everything the browser version does).
tim5055
10,822
Franklin, NC
FC 6.4
PH 7.6
TA 80
CH 260
CYA 40
Nope, we do not use that tale. Pluse your 80 being "lower than the desired range" isn't totally correct either.
Many of us have found that TA as low as 50 will help stabilize pH rise in our pool.
Reactions: beautifulpool
Bozer4
Active member
Jul 11, 2019
36
Manteca ca
Thanks for the info, I've been using the troublefree method and all is well with the pool, I just wanted to make sure I wasn't overlooking something.
Reactions: tim5055
Ted2019
21
Lido Beach, NY
I had the same question- thanks for asking! In my Taylor book, they qualify this correction method by saying that “ some in the pool industry question the value” of this adjustment.
I’ve following the TFP ABC’s and it’s been working very well for me —-LC with no more “pucks”, lower CYA, lower TA and stable PH. Now I’m switching to a SWCG.
Reactions: tim5055
