- Oct 21, 2020
- 12
Hi all,
Over the course of this swim season my team has had several issues maintaining CYA. First we had issues with Leslie’s granulated conditioner not raising CYA in some pools but working well in other pools. My employees would report inconsistent CYA readings that I chalked up to user error. I had all my guys switch to Leslie’s instant conditioner (pre-dissolved in water) and this seemed to remedy most of our issues until recently.
One of our clients pools turned green so I spent a couple weeks making visits myself to clean it up and testing FC, pH, and CYA almost every visit. Initially CYA was at 60ppm and pH at 7. I cleaned the pool up and handed the weekly visits back over to my employee and it immediately went green again. When I retested the conditioner it was at 0-10ppm CYA and 8+ pH.
To my knowledge, the only way CYA will decrease is by dilution with tap or rain water. We’ve been getting a lot of rain but for CYA to drop from 60ppm to almost 0 in the span of two weeks there must be something going on. The pool doesn’t have an automatic water leveler. My first assumption was that CYA being an acid could be neutralized by rising pH due to the back to back algae blooms. I’ve also read about high chlorine levels oxidizing CYA.
My questions are as followed:
1. Will algae blooms raise pH?
If so, will high pH neutralize cyanuric acid?
2. Could high chlorine levels from repeated shock treatments oxidize CYA?
3. What other chemical interactions can neutralize CYA?
All other info is helpful, thanks in advance!
