Taylor 2006 - already through 1 bottle of R-0013 (I see now why I should've purchased the 2006C.. refills already on the way).
27' round AG - 15,000gal
Current numbers -
FC-2.7
pH-6.9ish (slightly less than 7 per the scale)
TA-70
CH-100
CYA- right at 30 yesterday, <30 this morning after added 2lbs stabilizer.
Current season history - First season opening my pool (terrible cover plus foliage dump into pool while opening, pool was a swamp. vacuumed to waste and skimmed everything I could. added 2 lbs shock, ran 24 hours, vacuumed to waste, added 2 more.
Algae seemed to die, pool cloudy, went to a pool store the following weekend. On Saturday morning (MDW), they gave me 2 more lbs of shock, 8 lbs of something to adjust alkalinity. Told me that should raise my pH as well. pH has not changed at all, went back next day, they gave me a bottle of hydrofloc and told me it was my best bet. WOOF. Did it, water cleared, vacuumed to waste, as soon as the filter came back on, clouds.
Found TFP, did a deep dive in research here, ordered the kit, ordered some liquid chlorine and stabilizer (Walmart was the only local place that any, as I kind of don't ever want to go back to that pool store). Bought 20 Mule from a supermarket, and I'm ready to go.
Added 2 lbs dry stabilizer required by the calculator, no change, looks like it even dropped. Pool is cloudy, I brush brush brush but the greenish/brown on the walls will not budge. Pool was very well maintained by previous owner so all of this is new (I know I have to adjust the pH but don't want to do it without any advice first).
Ok that was lengthy. I've already spent a fortune this season (not including the water bill that I haven't seen yet) so I'm trying to simplify this as best as possible.
Thanks in advance!
Current numbers -
FC-2.7
TA-70
CH-100
Thanks in advance!
