Moved from here.
So I need a little help, I have to admit I’m baffled. Well, I have my suspicions, but I don’t want to mislead any advice so I’ll wait and see if I’m right. Testing for CYA has always seemed a bit of an inaccurate science to me, but I don’t recall having any major issues last season, albeit my first full pool season. I don’t close my pool, and while I have had to drain a couple of times this winter from rain, it didn’t seem to be as much as my CYA tests would reflect, but, my salt was also lower than I expected, so that seem to validate the low CYA levels I have been getting.
I’m a little paranoid about putting too much CYA in, so before adding any I ordered a bottle of R-7065 50ppm standard someone linked above to help make sure I’m seeing this little black dot as I’m supposed to. I did the test with the standard, and it’s not cloudy at all. The dot is nearly as visible as it would be with water. I fill the test tube completely full and it’s pretty much the same as at the 50ppm line. My original T-2006 R-0013 CYA reagents had an expiration date of 10/21, I order a 2oz bottle to refill them last September, and that bottle has an expiration date of 6/22.
We’ve been getting some longer sunny days this week, and my chlorine levels have been pretty constant, so I believe my CYA level is nowhere near as low as my initial tests have been showing. I’d really rather put this bag of CYA on the shelf and save for later than over load it in the pool because I’m getting erroneous test results.
What do you guys suspect is going on here. I’m using what should be good reagents, I’m doing the test with room temperature water, and I’m following the instructions exactly as it says and I have always done. Any help would be greatly appreciated.
