Moved from here.
Hi, Im new here and have a dumb question on this test. I am using the Pentair Rainbow CYA test and I have received conflicting info. I have filled the tube with pool water and then the reagent. Then stirred it up with the dipstick. Am I supposed to pull the dipstick up from the bottom and pull the reading when the black dot appears or pull the dipstick all the way out and lower it until the black disappears. The two methods give a much different reading (50ppm difference). The test strips line up closer the the latter option. I appreciate any help!
