Hey everyone!
As the title suggests, I am a green pool owner (both the amount of time I've owned a pool, and the color of the water!). The pool itself is a 13.5K gallon above ground, with a sand filtration system and a Hayward Chlorine Feeder.
I have been regularly vacuuming the pool and decided to begin a SLAM. I thought I got the Chlorine level high enough, but I don't think I did because the pool is now green. So I'm starting over again.
My current PH and TA levels seem to be okay per both the test strips and the TF100 test kit that I bought.
My current FC level is 3.5 PPM, and where I'm very confused is with the CYA test.
If I hold the bottom of the tube against a background that is light (but not super bright), I'm not seeing the black dot somewhere around 90-100. However, if I hold the bottom of the tube against a brighter background (like the light from a lightbulb), I'm reading about 45. Which is the proper way to read this test? I'm about ready to head to the pool store to get my test results verified, but figured it would be worth a check here first.
If my CYA is the higher level, then I think it best to get that down before attempting another SLAM (per my reading on here). Really hoping to avoid that though, as I'm on a well system. I attached a couple pictures as well, just for reference. Thanks in advance for any advice!
