Just to make sure I’m doing the Taylor test correctly, I fill the little bottle with pool water up to the 7ml level and then add the cya reagent drops up to the 14ml line.
if that’s the correct method, I guess it’s right. I find it strange that the cya reagent bottles are so small compared to how much of them you have to use for just one test. It looks like my new kit can only do that test 5-6 times. Should have got the other kit.
the Pentair kit just fills up a large sample of pool water, drop a tablet in and wait for it to dissolve. Then you lift the white stick up until you can see the black dot appear, then lower it until it disappears.
My FC levels have been working well with the CYA I thought I had so not sure what to do. I won’t be adding any stabilizer for the rest of the season I suspect so maybe I’ll leave it be and keep up with the chlorine levels I’ve been using.
