CYA reading off the charts??? Maybe??
Rocco1040
56
Lake Jackson
Brushed the walls, bottom, and every other possible spot. Last test was at 5:43pm just tested again and my FC went from 27 to 29. Not sure if I missed counted or it's still rising.
cfherrman
2,410
Hays, Kansas
Good idea, follow the slam instructions to the letter, you probably have algae and keep killing it and you have to sweep up the dead algae. The slam will completely erraticate the algae and you won't have any more dead bodies
Rocco1040
56
Lake Jackson
If that stuff on the bottom is algae will it begin to change colors as it dies?
And should I maintain a level higher then 24-FC during the slam to eradicate this algae problem I've had for almost 6 months
kellyfair
1,995
Tampa, FL
I want to get in to make a whirlpool and get all that stuff that's on the bottom into the middle and vacuum it out through the waste.
LOL, that’s exactly what I did!
Since 24 is your SLAM level with your CYA at 60, that’s the FC you shoot for during your SLAM. Just keep testing and raising chlorine to 24, keeping pump going and brushing and vacuuming. This will eliminate your algae, promise! Don’t forget hidden algae traps like stairs, ladders, etc.
Rocco1040
56
Lake Jackson
Just retested my CYA and it's over 70. I rushed that..... So now I'm draining more water. Did a whirlpool and got out so much of that gunk on the bottom. The bottom of the pool does not feel slimy.
Also after I refill it how long do I need to wait before I can retest my pH and cya and start this process over again??
