CYA question
DIYLinerPool
72
Chicago (West Suburbs), IL
Hi all - just got my tf100 test kit and tested the cya on my new liner pool I just filled a month or so ago. It is around 25. I am currently using tricolor tablets in an inline chlorinator. Should I just continue to use the tablets and test the cya more frequently (ie weekly) and stop when it gets around 40 or so? Or should I raise it a different way.
Also I have an automatic pool cover that I close daily , not sure if that affects my target cya level or not….
thanks!
mknauss
51,247
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
If you keep the pool covered during daylight most of the time, you can follow that process. Realize that your FC needs will increase as your CYA increases. The trichlor will not likely add enough chlorine each day, if you have the cover open and/ or swim. So test often.
Also watch your pH. Trichlor is very acidic.
Reactions: DIYLinerPool
