CYA levels in 3 month old pool
Stevo2440
5
Pearland Texas
New Plaster pool. First season. I use trichloride tabs in a chlorinator. My Cl levels were way high at first. Got a Taylor Test kit and now have that under control. Recently tested the CYA level and was 80. I know it’s in the high level, but Is it that high? Is it possible I got it that high in such a short time? Don’t want to get to Cl lock. Am I overreacting?
Thanks in advance.
zea3
12,694
Houston, Texas
Hi, welcome to TFP! You are not over reacting! You need to stop using trichlor/dichlor as it will add CYA. It is best to use liquid chlorine so your CYA doesn't get any higher. Check out this video for more on the chlorine/CYA relationshipl.
Reactions: Stevo2440
JJ_Tex
1,857
Prosper, TX (DFW)
There is no "lock" but, higher your CYA, the higher you need to keep your Free Chlorine (FC) levels. Check out the FC/CA chart in my signature.
At 80, you should be keeping your FC at 7+. That is fine, but people get into problems when they try to keep their pools at a FC of 3 regardless of their CYA.
zea3
12,694
Houston, Texas
CYA degrades very slowly. Draining some of the water is the only practical way to lower CYA levels. If you can get 10% liquid chlorine that would be best. You can find it at Walmart, pool stores, and big box hardware stores. If you can't get 10%, you can use 6% plain, unscented bleach from the grocery store.
Stevo2440
5
Pearland Texas
Would you recommend draining it myself? Or should I get a pro? My app I use suggests 33%
tim5055
11,061
Franklin, NC
CYA of 80 is not an "emergency"
If you switch to using liquid chlorine no need to drain at this point. Just raise your FC levels to take the higher CYA into account and bring the CYA down slowly. For a CYA fof 80 just keep your FC in the 9 - 11 range. Yes, it's safe to swim.
When I took over my pool the CYA was 250ish... I had to keep the FC around 20 most of the time. It took me about 18 months to work it down to a reasonable level.
Richard320
23,932
San Dimas, CA (LA County)
This.
You can maintain it easily at 80 CYA but be extremely careful about maintaining adequate FC and about brushing. You really don't want to get algae. If you do you'll pretty much have to drain, ready or not.
Stevo2440
5
Pearland Texas
This.
Yeah I’ve got some light yellow spots that I’ve been brushing. I think it may already be there. Goes away easily but come back a few days later. I shocked it and they’re still coming back. My Cl has been around 5-6 so it makes sense.
tim5055
11,061
Franklin, NC
Gotta bring that up to 9 - 11.
Our whole system is based on maintaining the correct level of FC in ratio to the CYA that's in the water.
